Used target = MCB-STR9 + µVision3.50 from Keil.
I tried to build the blinky example to boot and run in flash bank 1. In the "STR910 Flash with CFG", I changed, using the configuration wizard following items : FLASH MEMORY INTERFACE (in STR91x.s) Flash bank 0 Enable = true BBSize = 512KB BBADD = 0x800000
Flash bank 1 enable = true NBBSIZE = 32K NBADDR = 0x00000 (<= remapped this on address 0 to boot)
CONFIGURATION (in STR91xCFG.s) CSX (Chip select mapping) = true (<= switch boot sector)
The result is that the JTAG is blocked. I get the error 'could not stop ARM device'. Even erasing immediatly after reset is not possible. This is the second time this happens. The first time i did replace the STR9 device. Now I did order a RLINK device. I hope this works for erasing it !
My question : WHAT IS WRONG WITH ABOVE SETTINGS ?
Thanks Luc
