There's something I don't understand reading the tcpnet user guide . I want to code an simple FTP server that can manage at least 2 connections.
Si it seems I have to create a listening socket like the example from the user guide :
init_TcpNet (); tcp_soc = tcp_get_socket (TCP_TYPE_SERVER, 0, 30, tcp_callback); if (tcp_soc != 0) { /* Start listening on TCP port 80 */ tcp_listen (tcp_soc, 80);
But then , how to manage several connections ?
In lwpip stack for example , you create a listening socket associated with a callback fonction. When a client is connecting , the callback is called with a pointer to a new socket created by the stack to manage the new incoming connection .
In tcpnet the callback fonction is like this :
U16 tcp_callback (U8 soc, U8 event, U8 *ptr, U16 par) {
Does the 'soc' parameter is the new socket to use for transmission in the socket ?
thanks in advance.
