I am working on a Silicon Labroratories F340, and in my KEIL uVision3 I have found it in the "device database". I can make a project with this chip set. But when I compile the project, it showed error message "path for toolset undefined". I checked the tools.ini, it only contains my email address. Thanks.
Then you need to reinstall an C51 toolchain (perhaps you start with the current EVAL Version).
Thanks. you are right. It's OK now.
I use keil c51v809a for study. I use Windows Vista. When I start uVision It tells me that the path for toolset is undefined. I also can't edit new projects because of this error. What can I do, to rum uVision without errors?
The TOOLS.ini looks like this.
[UV2] ORGANIZATION="no" NAME=*** EMAIL=*** BOOK0="UV3\RELEASE_NOTES.HTM" ("uVision Release Notes",GEN) DEVICE_BOOKS= [C51] PATH="C:\Programme2\Work\Keil\C51\" BOOK0="HLP\Release_Notes.htm" ("Release Notes",GEN) BOOK1="HLP\C51TOOLS.chm" ("Complete User's Guide Selection",C) TDRV0=BIN\MON51.DLL ("Keil Monitor-51 Driver") TDRV1=BIN\ISD51.DLL ("Keil ISD51 In-System Debugger") TDRV2=BIN\MON390.DLL ("MON390: Dallas Contiguous Mode") TDRV3=BIN\LPC2EMP.DLL ("LPC900 EPM Emulator/Programmer") TDRV4=BIN\UL2UPSD.DLL ("ST-uPSD ULINK Driver") TDRV5=BIN\UL2XC800.DLL ("Infineon XC800 ULINK Driver") TDRV6=BIN\MONADI.DLL ("ADI Monitor Driver") TDRV7=BIN\DAS2XC800.DLL ("Infineon DAS Client for XC800") RTOS0=Dummy.DLL("Dummy") RTOS1=RTXTINY.DLL ("RTX-51 Tiny") RTOS2=RTX51.DLL ("RTX-51 Full")
My fault, I used the wrong software, sorry. ^^
