Hi, this fine stick from HITEX does not start without USB connection (needs enumeration)to a PC. Is there a way to run the microcontroller XC164CM only at 5V connection? Probably is the FTDI 2232L Chip the problem (clamp the microcontroller?). MProg for FTDI has no effekt. Probably is also the TRST-Pin ...
Thanks for answers and kindly regards RABIS
Not in this configuration, you need to be connected to USB. You can start it without the Hitex program by writing to the FTDI chip yourself to release the reset of the XC164CM.
