Problem: Big Delay of an Interruption
I'm using an AT91M55800 with an external clock of 3'57MHz, and all is working perfect.
At this moment, I only use 2 interruptions:
- Timer 0 interruption, to gererate a 5ms time base.
- PORTB interruption.
All peripherals work properly (display, keyboard, etc)
I only configure one PIN to use the PORTB interrupcion.
When happend a level change on that pin the PORTB interruption start, BUT with 100ms-150ms DELAY!
Is tooo big delay, If I listen the signal by pin status pooling, I don't have delay, only if I use the interruption. (The priority is 7)
What can be the problem???
Thanks!
