Uvision Hangs when downloading flash
Hello, It seems the uvision IDE hangs when I try to download code to flash memory in my LPC2131 part. I have both a Ulink and a Ulink2. The Ulink works just fine. The Ulink2 causes the hang-up. I downloaded the lastest software version 3.04. This applied an update to the ULINK2 when I plugged it in but still had the same issue. I have tried downloading with ULINK2 on several PC's but all with similar results. Any ideas will be appreciated.
Thanks,
Alex
