Is there a way to use macros, environment variables, preprocessor constants, etc. with the uVision project?
For example, if I want to change the name or location of the output file, is there a way to do it without manually going in the and editing the project?
I'm writing code for multiple processors and this would help to keep everything organized, plus automate thing a little more.
dead eaay
Drop the IDE and use a .bat file.
in one case I make 47 different builds from the same set of files (using file selection, file name change etc. Publish you e-mail address (use 'AT' instaed of '@' for safety) and I will send you an example of a .bat file.
http://www.keil.com/support/man/docs/uv3/uv3_ca_projtargfilegr.htm
