I am trying to send bytes from UART & SPI by involving ISR. Since there is no SPI simulation available in KEIL. For debuging purpose i toggle a pin after sening one byte from SPI port & then from UART.
In simulation it seems ok but in real scenario it does not work at all.
Before it i tried SPI in polling work which worked well.
The code is following
#include <AT898252.H>
unsigned char UART_RX=0; unsigned char SPI_RX =0; unsigned char SPI_RX_FLUSH=0; bit UART_TRANSMIT=0; bit SPI_TRANSMIT= 0; bit SPI_RECV= 0;
void UART_SPI_ISR(void) interrupt 4 { if(RI) {UART_RX=SBUF; RI=0; }
if(TI) {TI=0; UART_TRANSMIT=0;}
if (SPSR==0x80) { if(SPI_RECV==1) { SPI_RX=SPDR; SPI_RECV=0; }
if(SPI_TRANSMIT==1) { SPI_TRANSMIT=0; SPI_RX_FLUSH=SPDR; SS=1;} /* set software flag */ }
void UART_SPI_INIT() { /*--- Initialize the serial port.----------*/
TMOD = 0x20; PCON=PCON|0x80; TH1=0xFF; // BAUD RATE 57600 TR1 = 1; SCON = 0x50; /*--------- Initialize the SPI port------*/ SPCR = 0xD3; /* 11010011 */
ES=1; EA=1; }
/*----------------------------------------------*/ //-------------------------------------------- //UART SEND CHAR FUNCTION //-------------------------------------------- void SEND_CHAR_UART(unsigned char SND) {
while((SPI_TRANSMIT)||(SPI_RECV)||(UART_TRANSMIT)); if(UART_TRANSMIT==0) { UART_TRANSMIT=1; SBUF=SND; }
} /*-------------------------------------------*/ //-------------------------------------------- void SEND_CHAR_SPI(unsigned char SND) {
while((SPI_TRANSMIT)||(SPI_RECV)||(UART_TRANSMIT)); if(SPI_TRANSMIT==0) { SPI_TRANSMIT=1; SPDR=SND; }
//-------------------------------------------- //SPI RECV CHAR FUNCTION //-------------------------------------------- unsigned char RECV_CHAR_SPI() { unsigned char RECVD=0;
SPDR=0xFF; SPI_RECV=1;
while((SPI_TRANSMIT)||(SPI_RECV)||(UART_TRANSMIT)); if(SPI_RECV==0) { RECVD=SPI_RX; return RECVD; } }
/*----------------------------------------------------------------------------- -----------------------------------------------------------------------------*/ void main (void) {
UART_SPI_INIT();
while (1) { SEND_CHAR_UART(0x55); SEND_CHAR_SPI(0x55); P1_0=~P1_0;
language or understanding?
You can not do SPI in mode 1, SPI does not have start and stop bits.
In AT89S8252 SPI & UART share same interrupt & for occur SPI interrupt it is must to SET 1 ES & SPIF.
