Return from a function is not stable! - C51
Dear All,
In the below program, main function calls "yaz" function 10 times. it works fine without any problem with the global variable definition marked as "bold" "unsigned char i" altough it is not used in the program. When I ignore or delete this definition line, "yaz" function enters endless loop and never returns to main program. Any idea what the problem is about?
regards.
akif
#include <reg51rd2.h>
unsigned char data gdeger[8];
//unsigned char i;
unsigned char code rakam[10][8]= {      {0x00,0x00,0x7E,0x81,0x81,0x81,0x7E,0x00},      [..]
        Data lines deleted for proper format
void bekle(unsigned char j){
        unsigned char i;
        for (i=1; i<=j; i++){
                TMOD =0x01;
                TH0 = 0xFE;
                TL0 = 0x00;
                TF0 = 0;
                TR0 = 1;
                 while (TF0 == 0);
                TR0 = 0;
}//bekle
void yaz (unsigned char gonder[]){
        unsigned char row;
        unsigned int col;
        unsigned char i;
        unsigned char n=7; //sola kayd&#305;rma miktar&#305;
        unsigned char sdeger;
        unsigned char goster;
        for (i=1; i<=8; i++) {
                for (row=0;row<9;row++)      {
                        sdeger=gonder[row];
                        sdeger=sdeger<<n;
                        sdeger=sdeger&0x80;
                        gdeger[row]=gdeger[row]>>(1);
                        gdeger[row]+=sdeger;
                }//for row
                row=0;
                n=n-1;
        for (goster =1; goster < 15; goster++) {
                for (col = 1 ; col < 256 ; col <<= 1){
                                P2 = col ;
                                P1 = ~gdeger[row++];
                                bekle(1);                       }//for col
                row=0;
        }//for goster
        } //for i
        for (goster =1; goster < 100; goster++) {
                                P2 = col ;
                        row=0;
                }//for goster
}//yaz
void main (){
        unsigned int s;
        P1 = 0;
        P2 = 0;
        ET0 = 0;
        while(1){
        for (s=0; s<10; s++)
                yaz(rakam[s]);
         }//while
}//main
