local array variables in debugger watch-local window not right...?
I detected a strangeness during function's debugging. Local array in Watch/local window was shows with incorrect Address and values. Is this IDE's mistake (uVision3 V3.34) or my incompetence?
____________________________________________________ small example: a) Programm's source with breakpoint: ......................................... void lcd_print (unsigned char const *string) { char AAA[5] = "11"; char * pc; pc = AAA; --> while (*pc) ......................................... b) Information in Watch/local window: ......................................... AAA |0x4000414[...] +--[0] |0x00 +--[1] |0x00 +--[2] |0x00 +--[3] |0x00 +--[4] |0x00 pc |0x400043C +--*pc |0x31
It is incomprehensible:
Why AAA and pc has different addresses? Why *pc show correct value 0x31 = '1', but AAA[0] - incorrect?
Eugeny
PS. However, function work correctly!!!
This looks ok here with uVision 3.50b and SARM.DLL V3.04a. The stack frame gets valid once you reach the line 'pc = AAA;' - it is not valid before:
void lcd_print (unsigned char const *string) { char AAA[5] = "11"; char *pc; pc = AAA; // AAA[] init is actually done here ! while (*pc++); } int main (void) { lcd_print ("Tester"); ... } AAA |0x00000308[...] +--[0] |0x31 +--[1] |0x31 +--[2] |0x00 +--[3] |0x00 +--[4] |0x00 pc |0x400043C +--*pc |0x31
Thank for answer, Peter! As I understood, You check in sumulate mode. I tray this example in sumulate mode too (earlier I works in JTAG-debugging mode with MCBSTR9 Evaluation Board). Of course, I check the variables after "pc = AAA;" operator. But uVision 3.34 do not working properly in both modes. I get uVision 3.34 with Keil MCBSTR9 Evaluation Board and Keil JTAG-2 adapter in December 2006. Where I can get trial-version uVision 3.50b?
