hi,
i am using an INSTEON microcontroller developed by SMARTHOME.PLC is connected to the serial port of the PC. I have to use an IDE called as SALad IDE, to develop the INSTEON applications.and the developed program should be downloaded to serial connected device .then that device can able to function on its own,without the need of PC.my developed SALad coreapp program should be such that it should control the brightness and dimness levels of the lights. the plc is connected with the another insteon device called as lamplinc dimmer.it will control the all lightning applications in the home.the devices will communicate over the powerline by using insteon messages.SALad program is an event driven program. SALad is a mix between assembler and BASIC. suggest me how to write the brightning control and dimness control routines.
Before posting to any internet forum, you must make sure that your post is relevant to that forum; ie, that it is "On-Topic"
So, read this: http://www.keil.com/forum/
Then ask yourself, does anything in your post have anything to do with any Keil Product?
