Agsi.h file for uVision 3
Hi all,
I am currently using uVision 3 Debugger. In the sample examples available for download, there is a file agsi.h. This file is specific to uVision 2.
Surely, for the enhancements in uVision3, the file name "agsi.h" has changed. I could not find this file in any of the examples available for download.
It would be great, if anybody could help me out on this.
Pankaj
  • If you are just using the debugger, you don't need Agsi.h.
    Agsi.h has nothing to do with your embedded C51 code;
    Agsi.h is for people who are developing new debugger interfaces.
    "Surely, for the enhancements in uVision3, the file name 'agsi.h' has changed"
    Why would the name change?
    Also, if the the interface remained unchaged, there would be no reason to change the file.
    I beleive that both uVision-2 and uVision-3 use the same AGSI?
  • I need Agsi.h, to add peripherals to the debugger project. (where peripherals are included as dlls).
    Yes : That is true but enhanced support has been provided for Agsi calls like "setWatchOnSFR". An extra parameter is added to this function. And similar changes have been made.
    In that respect, i needed Agsi.h file and corresponding modified AGSI Definitions i.e. Pdf .
    If anybody is having them do reply.
    Thanks,
    Pankaj
  • In that case, you need to contact Keil direct.
    This is not the place to contact Keil - see: http://www.keil.com/forum/
