I am using LPC2378.I used the example code and its working. I can transfer a byte to & from the device. But the problem is that i cannot transfer a block of data from the to and from the device. In the system side the output report length & input report length is shown as 2. What could be the problem. Any help in this matter is highly awaited.
Regards, Som Appu
Did you read already this informatation?
http://www.keil.com/appnotes/docs/apnt_195.asp
Hello Som Appu,
Please take a look at the application Note http://www.keil.com/appnotes/docs/apnt_195.asp.
In this application note it is also explained how to enlarge the data structure which is transmitted.
Best Regards, Martin Guenther
