Hello, is it possible to access memory pages with the C167(infineon) that are bigger than 16kB? 16kB per page are to small for my application.
You can access any memory location on a C167. What is the problem exactly? Or are you talking about memory access using DPP registers?
What memory model are you using? See http://www.keil.com/support/man/docs/c166/c166_le_memmodels.htm But even this does not have a 16KB memory limit.
Kind regards, Joost Leeuwesteijn
See also: http://www.keil.com/support/man/docs/c166/c166_le_memtypes.htm
