ST timer problems
Could you help to install the ST timer on the AT91Rm9200? I don't know how to setup the AIC registers correct. Maybe there are more than one big mistake.
void initialize_pit()
        unsigned int  flag, period, irq_id, mask, oldHandler, src_type, priority;
        volatile int status;
        void *newHandler;
        //period
    Timer0->ST_PIMR = period << 5;
        AT91F_ST_SetPeriodInterval(Timer0, period);
        //state
        //status = Timer0->ST_SR;
        //enable interrupt
        flag=1;
        Timer0->ST_IER = flag;
        AT91F_ST_EnableIt( Timer0, flag);
        //enable PMC
        AT91F_PMC_EnablePeriphClock(AT91C_BASE_PMC, 1 << AT91C_ID_IRQ0);
        //config AIC
        irq_id = 0;
        oldHandler = pAic->AIC_SVR[irq_id];
        mask = 0x1 << irq_id;
        pAic->AIC_IDCR = mask ;
        pAic->AIC_SVR[irq_id] = (unsigned int) newHandler ;
        //* Store the Source Mode Register
    pAic->AIC_SMR[irq_id] = src_type | priority  ;
        AT91F_AIC_ConfigureIt(pAic, irq_id, priority, src_type, newHandler);
        //enable AIC
        AT91F_AIC_EnableIt(pAic, 1);
I hope somebody could help me with this problem...
best regards
johannes
  • Per could you tell me which parts of the code are not correct?
    It looks fairly correct now.
    How do you test it ? Are you working with an emulator/ICE and are able to set a breakpoint in the ISR ? Are you waiting for the chip to send something over the USART (which may or may not be initialized correctly, your code doesn't show that part nor any calls to an initialization function) ?
    Personally, I am working with the fairly similar AT91SAM7S, and did get the PIT to work.
  • the usart is working correct - I test it. Therefore there must be still a problem that the ST_interrupt function don't run.
    AT91PS_USART COM1_1;                                               /* Variable COM1 für die Struct _AT91S_USART definieren */
    void initialize_usart1()
            COM1_1= AT91C_BASE_US1;                         /* AT91C_BASE_US1 ist die Base-Adresse für den UART1 */
            /* Define RXD and TXD as peripheral     */
        AT91F_PIO_CfgPeriph(AT91C_BASE_PIOB,AT91C_PB21_RXD1 | AT91C_PB20_TXD1,0);
            // First, enable the clock of the PIOB (for the USART)
            AT91F_PMC_EnablePeriphClock ( AT91C_BASE_PMC, 1<<AT91C_ID_US1 ) ;
            // Usart Configure
            AT91F_US_Configure (COM1_1, MCK,AT91C_US_ASYNC_MODE, 115200, 0);
            // Enable usart
            COM1_1->US_CR = AT91C_US_RXEN | AT91C_US_TXEN;
            // setzen der beiden Variablen im US_CR Register
            AT91F_US_PutChar (COM1_1,'X');
            while( !(COM1_1->US_CSR  & AT91C_US_TXRDY) )
                         continue;
    I'm working with uvision3 and ulink2.
    johannes
  • when I start the program, I can send one character 'u' via the usart - but that's it.
    johannes
  • AT91F_AIC_ConfigureIt(pAic, irq_id, priority, AT91C_AIC_SRCTYPE_INT_LEVEL_SENSITIVE, ST_interrupt);
    Try configuring the AIC before doing everything else (especially enabling interrupts) during the initialization of ST (or any other peripheral). It might not be the problem here, but sticking with this convention may save you some debugging headaches later on.
    void ST_interrupt(void)
    You may want to add the __irq keyword here, like this:
    void ST_interrupt(void) __irq
    Also:
    void timer()
             unsigned int st_interval;                              // intveral st timer
             initialize_usart1();
             initialize_st();
             *(AT91C_ST_PIMR) = st_interval;                // value for the st timer
    You are still assigning the value of an uninitialized local variable to something else. This is a very bad idea. C convention does not require uninitialized local variables to have any particular value by default - they could have _any_ value. You're basically using a (bad) random number generator to set the value of ST_PIMR here.
    The compiler should be printing a warning message here. Warning messages usually have a good reason.
    Do you have access to an emulator (i.e. can you set breakpoints in the program and single-step through it) ?
    If so, try setting a breakpoint inside the ST interrupt handler. Also, try setting one inside the ST initialization function and single-step through it (you should also be able to watch the contents of the ST registers change).
  • thanks for your help...
    I set breakpoints in the initialize_st() and the ST_interrupt(void) function. When I run the programm, the initialization and the ST_interrupt method are executed and then the program ends in the while(1) loop - doing nothing. Therefore I get only a message via the usart. the status register is 1 after the line
    here is the whole code again
    #define    MCK     60000000                                        /* Clock-Rate für USART */
            // Usart Configure
            // Enable usart
     AT91PS_ST Timer0 = AT91C_BASE_ST;
     AT91PS_AIC pAic = AT91C_BASE_AIC;
            //clear ST_SR - muss ausgelesen werden
            //usart1
                        continue;
            AT91F_US_PutChar (COM1_1,'n');
            //clear the interrupt - zurücksetzen des Interrupts
            AT91F_AIC_ClearIt( AT91C_BASE_AIC,AT91C_ID_SYS );
        //the end of interrupt durch lesen dieses Registers - letzte Aktion
        AT91C_BASE_AIC->AIC_EOICR = 0x0;
    void initialize_st()
            //config AIC
            AT91F_AIC_ConfigureIt(pAic, AT91C_ID_SYS, AT91C_AIC_PRIOR_HIGHEST - 6, AT91C_AIC_SRCTYPE_INT_LEVEL_SENSITIVE, ST_interrupt);
            //unsigned int period;
            Timer0 =  AT91C_BASE_ST;                        /* Base Address for the ST Timer */
            //period = 0x0;
            // Set Periodic Interval Interrupt (AT91C_ST_PITS = Period Interval Timer Interrupt; Timer0 = Basis Adresse für ST)
            AT91F_ST_SetPeriodInterval(Timer0, AT91C_ST_PITS);
            //#define AT91C_ST_PITS         ((unsigned int) 0x1 <<  0) -> 0x1 = 0001 -> gesetzt ST_IMR Register (Interrupt enabled)
            AT91F_ST_EnableIt(Timer0, AT91C_ST_PITS);
            AT91F_AIC_EnableIt( pAic, AT91C_ID_SYS);
            // enable all mIRQ interrupts
            AT91C_BASE_AIC->AIC_CISR = 0x1 << 1;
    void timer()
             initialize_st();
             while(1);
    When I add this line
    what's the right request in the line
    Could there be something wrong in the startup-file? I sue the startup-file from keil.
    johannes
  • You most definitely must use the __irq keyword for the interrupt handler - unless you write in assembler and yourself write the correct code for entering/leaving the interrupt handler.
    Please don't sue the startup file - this world is already too full of busy lawyers ;)
  • could you explain me how I have to change this line
    AT91F_AIC_ConfigureIt(pAic, AT91C_ID_SYS, AT91C_AIC_PRIOR_HIGHEST - 6, AT91C_AIC_SRCTYPE_INT_LEVEL_SENSITIVE, ST_interrupt __irq);
  • Please read all the comments above, and then explain why you think that you should use the __irq keyword in the function call.
    The information you have received is that your Interrupt Service Routine (ISR) should be declared with the __isr keyword. You have even received an explicit example how that source line should be written.
    Have you looked at _any_ example code for your processor? You can hardly find any example code that doesn't contain at least one ISR.
  • yes, but when I write
    I get a error in this line
    because the typ void (*)() __irg is not compatible with parameter of type void (*) ()
    johannes
  • When I run the programm, the initialization and the ST_interrupt method are executed and then the program ends in the while(1) loop - doing nothing.
    The ST interrupt handler is executed exactly once, is that correct ?
    If so, that's already a good lead. It means that the interrupt is enabled and responsive.
    The AIC_ICCR has no effect on level-triggered interrupts. This line is unnecessary, as the PITS interrupt will be cleared by reading ST_SR. Try the following line to read ST_SR at the end of the ISR:
    AT91C_BASE_AIC->AIC_EOICR = AT91C_BASE_ST->ST_SR;
    Setting the ST_PIMR to "AT91C_ST_PITS" doesn't make much sense. AT91C_ST_PITS is defined as
    #define AT91C_ST_PITS             (0x1 <<  0) // (ST) Period Interval Timer Interrupt
    and intended to be used when accessing ST_SR or the various registers dealing with the ST interrupts (ST_I?R). The second parameter given to AT91F_ST_SetPeriodInterval should be the number of milliseconds that you want the PIT interval to be.
    Also, be aware that AT91F_ST_SetPeriodInterval disables the PITS interrupt (which shouldn't matter here just yet, since you enable it after the call to the function. I'm just mentioning this for the record.)
    AIC_CISR is a read-only register (see datasheet, p. 256, 22.8.9 ). Writing to it is pointless.
    Adding the __irq keyword doesn't change anything in the AIC configuration. It just tells the compiler that this function will be used as an ISR, and must be compiled in ARM mode.
    I don't believe so. The startup file only does some fairly generic initialization.
  • In that case, some typecasting might be required:
    AT91F_AIC_ConfigureIt(pAic, AT91C_ID_SYS, AT91C_AIC_PRIOR_HIGHEST - 6, AT91C_AIC_SRCTYPE_INT_LEVEL_SENSITIVE, (void (*) ()) ST_interrupt);
  • thanks a lot - now it is working...
    How can I see in which mode the prozessor is working? I thought that would be correct initialised in the startup file?
    That's true - I just see this code by a example in the www, and I wondered...
    johannes
  • How can I see in which mode the prozessor is working?
    You mean whether it's in ARM mode or in THUMB mode ?
    Various compiler settings and preprocessor commands can influence this. You can set a "default" mode in the project settings, but then override the default by using preprocessor commands (see the compiler manual on how to do this). THUMB mode code is generally smaller and usually somewhat slower than ARM code (it can be faster if your system is working with a 16-bit memory interface instead of a 32-bit memory interface). However, interrupt service routines must always contain ARM code since the processor switches to ARM mode when it enters an ISR.
    If you write programs in assembly, you have finer (and basically complete) control over the processor mode. In assembly, the mode can be changed with special branch instructions.
  • yes I read the datasheet about thumb and arm code...
    ok - that means that without __irq the prozessor don't run in the right mode (irq mode which can only be in arm mode). I thought that when I create a irq that the prozessor knows that he has to run this code in arm mode... ok but that was the mistake...
    johannes
