I am working with the AM29F800B Flash. I earlier struggled to get the new Flashing Algorithm but was successful in creating an algorithm with the help from this forum. Now I am able to erase the Flash Device but I'm still having trouble in writing to the Flash device. Kindly suggest some tips on programming the Flash.
Hallo,
As soon as you can erase the flash, writing to it should not be a problem. In your e-mail you have to specify more details in order to be answered correctly. Nevertheless, here are some tips.
1) Double check whether you work with address space correctly. Check if your MCU's A1 address line is connected to the A0 of the flash (a typical h/w implementation for word organized memory). In this case you will need construction like this (pay attention to the << shift):
#define FWr(X, Y) *(unsigned int volatile far *) (FLASHBASE+((X)<<1))= (Y) #define FRd(X) *(unsigned int volatile far *) (FLASHBASE+((X)<<1))
in order to access the flash correctly to perform write/read operations. Do not forget to define your FLASHBASE (typically this is 0x0)
2) Now, assume: a) you have your data transferred successfully to the target's (external) RAM space, b) chip has been erased. All you need now, is to call a function similar to that shown below:
// ************************************************ // Baklanov N., Oct-2007 // Write buffer buf[] to the AM29F800BT flash // ************************************************ static int buf2amd(long address, WORD n, WORD far *buf) { WORD far *wPtr= &buf[0]; WORD W; WORD status, old_status, err= 0; while(1) { W= *wPtr++; FWr(0x555, 0xAA); FWr(0x2AA, 0x55); FWr(0x555, 0xA0); FWr(address, W); address+= 1L; old_status= FRd(0x0); // any allowed address while(1) { // -------------------------------------- status= FRd(0x0); // 40h: DQ6, Toggle bit I if((status & 0x40) == (old_status & 0x40)) { // DQ6 is not toggling anymore ... break; // ... means that the erase op. has completed }; // we are here IF the DQ6 is toggling, i.e. erasing is in progress if( (status & 0x20) ) { // DQ5= 1 means flash has exceeded time-out old_status= FRd(0x0); status= FRd(0x0); if((status & 0x40) == (old_status & 0x40)) { // DQ6 is not toggling ... break; // ... erase op. has completed }; err= 1; // DQ6 toggled means flash has a problem break; }; old_status= status; }; // while(1) : waiting flash --------------------- if(err) break; n--; if(!n) break; }; // main loop to write whole next array return err; }
3) You may also want to reset flash:
FWr(0L, 0xF0); // reset AMD
before accessing it, to make sure the chip is out of autoselect mode (if you had recenly read ID out).
4) And... do not forget to bypass those flash addresses which are inherently assigned to internal MCU's space. E.g., for C167CS it would be the 00'E000h ... 00'FFFFh window - see datasheet.
Regards, Nikolay.
I have a 1MB flash starting from 0x0 to 0x100000 and RAM of 256 kb starting from 0x100000 upto 0x140000 when i generate my code the code section is in ROM and data section is in RAM. I use CS1 to select the chip select logic for RAM start adress from 0x100000 and size 256KB when i download the FLASH AM29F800bb it fails in mid way 0x40000. I dont understand, is it all right to download the data in RAM? or am I making some mistake here?
You need your code running from the RAM.
