My emulator supports a nonstandard 8051 MCU.I have made a keil AGDI driver for it.But i found there are some Peripherals unsupported by my MCU are listed under the Peripheral menu.(Such as CAN,PORT0-5,Timer)My MCU don't have these peripherals and I don't add these menu in my agdi code.I wonder where these peripheral menus are from and how to remove them.
Please give me some idea
You need then to select a different device. Which CPU CORE is the base for your device? Did you review other devices that may come close to yours.
Thank you for your help.I have removed the contents of "dialog dll" in "debug" options of keil,the extension menu is disappear now. So i decided to remove the "dialog dll" and its parameters from my device database.
