FLIP Issue - AT89C51CC03 - Vector Hardware
We are having an issue with FLIP 3.2.0 which also exists on previous versions (ex. 2.4.0) Here is the problem:
- Using an AT89C51CC03 and batchisp.exe with Vector Hardware (CANCASE XL)
- First pass through programming the device, we get an error on "READING BOOTLOADER VERSION" - Software Security Error. However, the device programs fine, passes verification and works great.
- Same part second pass through - Get no errors â€" works great
- Same part third pass through - get this error: Programming memory..................... FAIL CAN message ID is not valid.
- Now that part is done - it can no longer be programmed.
0
