I'm trying to locate a variable to an specific address. There are three ways to do this:
1) using options of the file that have the variable and config the RAM area 2) unsigned int cont __at (0x2000000); 3) #define cont (*((unsigned int *)(0x2000000)))
The first one, is too bad because is posible that I want to locate variables to diferents locations. The second one, is perfect for me, but when compiling the compiler generate a very big file from CODE area to RAM area even using a not init area. The third one, works perfect, but is not a standard way to do it.
How can I use __at tense without make a very big file?
My code are located at 0x1000000 and the data are at 0x2000000.
Thanks!!!
I have use style 3 on my projects. Why do you consider it not standard? Following is a line from a lpc project.
#define IOPIN0 (*((volatile unsigned long *)0xE0028000))
"#define IOPIN0 (*((volatile unsigned long *)0xE0028000))"
The trouble with this is that the tools do not know that you are using location 0xE0028000 - so there is nothing to stop them putting something else there...
Thank you!!
Ever all my projects use __at tense, is more easy to read, but now I like the third option because I can see that you use it. Thanks.
Finally I use this:
#define _at(x) (*((volatile unsigned int *)(x))) #define uchar_at(x) (*((unsigned char *)(x))) #define uint_at(x) (*((unsigned int *)(x))) #define ulong_at(x) (*((unsigned long *)(x))) #define char_at(x) (*((char *)(x))) #define int_at(x) (*((int *)(x))) #define long_at(x) (*((long *)(x)))
There are not "volatile", because is not a register and ever the compiler knows when it change.
Thanks!!
But see my previous warning:
"The trouble with this is that the tools do not know that you are using the pointed-to locations - so there is nothing to stop them putting something else there..."
Thats is clear, but, there are any other method to do this with the supervision of the compiler?. Using __at directive the results are not good.
