Hello
I am trying to define a segment of 259 bytes at a specific address in my XRAM. I am using assembly and I am doing the following:
PROG SEGMENT CODE STACK SEGMENT IDATA DOWNLOAD_BUFFER SEGMENT XDATA RSEG DOWNLOAD_BUFFER DS 259 XSEG AT 0100h RSEG STACK DS 10H ; 16 Bytes Stack CSEG AT 0 USING 0 ; Register-Bank 0 ; Execution starts at address 0 on power-up. JMP START RSEG PROG ; first set Stack Pointer START: CLR P2.5 CLR P2.6 ;Config I2C ;Set I2C interface CLR SPE MOV I2CADD, #44h MOV I2CCON, #80hinterrupt. MOV DPCON, #04h MOV CFG841, #01h CALL INIT_RAM ?ProcessI2C: CALL GET_NEW_I2C_DATA JMP ?ProcessI2C
The segment "DOWNLAOD BUFFER" is properly created and the length of it 259 bytes like I want to. However, I cannot set it at address 100h like I'd like to.
When I look at the map file, I see the following:
TYPE BASE LENGTH RELOCATION SEGMENT NAME ----------------------------------------------------- * * * * * * * D A T A M E M O R Y * * * * * * * REG 0000H 0008H ABSOLUTE "REG BANK 0" IDATA 0008H 0010H UNIT STACK * * * * * * * X D A T A M E M O R Y * * * * * * * XDATA 0000H 0103H UNIT DOWNLOAD_BUFFER * * * * * * * C O D E M E M O R Y * * * * * * * CODE 0000H 0003H ABSOLUTE CODE 0003H 0135H UNIT PROG SYMBOL TABLE OF MODULE: I2C Slave Polling ASM only (MAIN) VALUE TYPE NAME ---------------------------------- ------- MODULE MAIN C:0003H SEGMENT PROG I:0008H SEGMENT STACK X:0000H SEGMENT DOWNLOAD_BUFFER
DOWNLOAD_BUFFER is set at address 0000h and not at 100h like I would expect it. Why? Could someone tell me what I am doing wrong or what I should do?
Thanks a lot Laurent
I would guess it's because the segment "DOWNLOAD_BUFFER" is a generic segment with 259 bytes, which the linker can place anywhere it sees fit.
After that, the XSEG directive switches to an absolute segment, which has nothing to do with "DOWNLOAD_BUFFER".
You can either tell the linker to place the segment "DOWNLOAD_BUFFER" at X:0x0100, or re-check how you define and switch segments in your assembly file.
http://www.keil.com/support/man/docs/a51/a51_st_segment.htm
http://www.keil.com/support/man/docs/a51/a51_st_xseg.htm http://www.keil.com/support/man/docs/a51/a51_st_rseg.htm
