Why can't I transmit more than 1 byte at a time on a USB bus?
Hello all,
I am trying to send a couple of bytes from an ARM7 to my PC. but whatever I do (I adjusted the packet size in the USB endpoint descriptor) the PC either receives one byte (if I sent one) or garbage, if I dare to send more. Do you have an idea as to what is going wrong?
Thanks in advance,
Tamir
