Error L6204E Entry point (0x0000000) does not point to an instruction.
What is the deal here. I copied most of the files from pwm.c and just added an interrupt routine. at address 0 we are supposed to get vectors not an instruction.
"at address 0 we are supposed to get vectors not an instruction."
And what are "Vectors" if not pointers to Instructions?
It is expecting an instruction at address 0 -
These are "normal" instructions starting at address 0
Vectors LDR PC,Reset_Addr LDR PC,Undef_Addr LDR PC,SWI_Addr LDR PC,PAbt_Addr LDR PC,DAbt_Addr
These are actuall instructions, 4 bytes long, starting at address 0. These are not vectors.
Hi Art. That looks like a problem I had - if so, you can solve it by right clicking on your project name in the project workspace, selecting OPTIONS FOR TARGET *project name*, then putting "--entry Reset_Handler" (without the quotes obviously) under the LINKER tab in the MISC CONTROLS box.
Hope this helps
Tim
