The weak sign from the sensor need to be amplified and counted by 8051 counter, then displayed on LED. How would I do this? I would appriciate it if someone can display the code in order for me to program my at89s52.
Thank You for your help, J.Bradshaw
As ever, the approach is to break the project down into smaller, simple parts:
"The weak sign from the sensor"
I presume you mean "signal"?
"need to be amplified"
Part 1: design an amplifier. Sites such as Analogue Devices, National Semoconductor, Texas Instruments, et al have a wealth of information on sensor signal conditioning.
"counted by 8051 counter"
Part 2: design a counter You need to decide how your 8051 will recognise the sensor "events" (interrupt? polling? other?), and then just count 'em
"then displayed on LED"
Part 3: design an LED display
Linke them all together!
So far I got part 1 finished. Now what I need is a code that will count up each time data in has change. i am using Keil uVision3 and so far I have: org 00h goto main org 30h main:
and you expect to get anywhere without even taking a perfunctionary glance at the "getting Started Guide"?
that little bit of code is wrong. Either is is faulty assembler (goto) or it is faulty C (org) in either case it is faulty.
... "perfunctory"
done quickly, without taking care or interest
dictionary.cambridge.org/define.asp
'scuse this non-native english speaker.
Thanks anyhow, that one was a 'wrong" not a "hasty mistype".
So by the "a day is wasted where you did not learn something" you saved my day
Are you coding in C or ASM?
What is the frequency of the signal?
asm frequency of 1kHz
