I am trying to creat my own project with DEMO uVersione 3.03. I copied the c and header files from RTX_Blinky sample Keil project which comes with the DEMO software to a new folder. I also made a new project name for it, and did some setting (my ev boad is at91sam7a3-ek). when I do compile, it give me lost of errors:
RTX_blinky.axf: Error: L6218E: Undefined symbol _init_box (referred from rtx_config.o).
RTX_blinky.axf: Error: L6218E: Undefined symbol os_clock_TCB (referred from rtx_config.o). .....etc.
My question is how this happens, and can I creat my own project with a DEMO wersion.
Thanks a lot....
Ben
http://www.keil.com/support/man/docs/uv3/uv3_creating_apps.htm
Thanks for your fast reply.
I tried to follow this tutorial. the first step is to set the "Components, Environment and Books", (I am using RealView compiler). however once I click OK, a system error notice will be shown: "uVersion IDE has encountered a problem and needs to close". and then the uversion will be closed. Strange..
I think you can, do some simple applications, but be careful with the settings.
I also got nearly the same problem when copy working c file to another project, then it stop working, i don't know why.
