I have a C8051F340. It has 4k of external ram, 256 bytes of ram and 1K of USB FIFO ram. I'm very confused on how to use the 1K of USB Ram as general purpose external ram with the Keil compiler.
The data sheet states that when the USBFAI bit in register EMI0CF is set to 1, the USB Fifo space is mapped into XRAM at address 0x400 to 0x7FF. It says the normal XRAM at the same address cannot be accessed at this point.
So I thought that I could set that bit and access the normal XRAM above 0x7FF (2k) and let it wrap around after 4k to get the first 2k. (5k gets mapped to 1k, etc). This didn't seem to work, however. Is this how its supposed to work?? How do I use the extra 1k? Is that 1k really not extra ram, but just the XRAM thats set aside for USB endpoints? Thank you!
"when the USBFAI bit in register EMI0CF is set to 1, the USB Fifo space is mapped into XRAM at address 0x400 to 0x7FF."
So, when the bit is clear, your XDATA memory map looks like this:
0x000-0xFFF - 1K "normal" XRAM
and when the bit is set, your XDATA memory map looks like this:
0x000-0x3FF - 1K "normal" XRAM 0x400-0x7FF - 1K USB FIFO mapped as XRAM 0x800-0xFFF - 2K "normal" XRAM
"5k gets mapped to 1k, etc."
What makes you think that? If the datasheet doesn't specifically state it, don't assume it.
Why do you want it to wrap any way? Why don't you just acces the 0x000 to 0x3FF memory directly?
So you're saying that my space is 0 to 4k whether I use the USB fifo or not, and I can't actually get 5k of usable ram?
I was trying to wrap the address around to get 5k of ram.
You said: It says the normal XRAM at the same address cannot be accessed at this point.
That seems to be the answer to your own question. When you map in the 1kB FIFO RAM, you can't at the same time use all of the 4kB of external RAM.
If you need the extra space, you will have to bank-switch, and preferably make sure that no interrupt routine makes use of any variables within the bank-switched range.
Thank you very much for the information. The guys at silicon labs insist that there is 5k of ram, but it appears thats not transparent with a C compiler.
"The guys at silicon labs insist that there is 5k of ram"
They are correct: there is 5K of RAM.
Nowhere do they claim that you can access all 5K simultaneously; in fact, your original post actually quoted the bit that says that you cannot access the 1K of FIFO and that 1K of XRAM simulatneously!
"it appears thats not transparent with a C compiler"
It has absolutely nothing to do with the 'C' compiler. You can switch that bit in 'C' and access the memory as described.
You could even set up the banking support to do this "transparently" for you, if you wanted...
this is what I've done to test the memory:
I've declared a variable static xdata uint8t_t test[1024] _at_0x400
Now I write values to it and print them to the uart //EMI0CF |= 1<<6;
for(i = 0; i < 1024; i++) { test[i] = i; } for(i =0; i < 1024; i++) { printf("%c ", test[i]); }
This works fine.
now if I do the same thing and select the alternate bank by setting the USBFAE bit in EMI0CF to 1, the memory is not written to at all. CLKSEL = 0x03; EMI0CF |= 1<<6; for(i = 0; i < 1024; i++) { test[i] = i; } for(i =0; i < 1024; i++) { printf("%c ", test[i]); }
The USB clock should be enabled and we should now be pointing to the USB fifo data area, right??
Thank you for you help.
