System clock has been set back
We get the following errors (8 out of 10 times) when trying to compile (the samplecode)
Error C3397E - System clock has been set back
or
Error L0589E - System clock has been set back
or
Error A0594E - System clock has been set back
We installed the same version
<mdk304.exe size: 68.130.552 byte>
IDE-Version:
µVision3 V3.50
Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2007
on a second (identical!) computer
There the problem does not occur.
Unfortunately i need the second machine for other tasks, so i need to run the µVision3 compiler on the one not working :-(
Does anybody has a clue how to get rid of those "System clock has been set back" messages?
- Arndt
p.s. We only use local file system and no network drive.
