Good day, in order to become familiar with the MCBSTR9 I first modified the Blinky program. That wasn't too difficult. But stage two was to write the same program using my own syntax and referring to the ST Software Library (www.st.com/.../12238.pdf). Done this, I yet only tried to set up the GPIO7:
#include<91x_map.h> #include<91x_GPIO.h> int main(void){ GPIO_InitTypeDef GPIO_Initialiser; GPIO_Initialiser.GPIO_Pin = GPIO_Pin_7; GPIO_Initialiser.GPIO_Direction = GPIO_PinOutput; GPIO_Initialiser.GPIO_Type = GPIO_Type_PushPull; GPIO_Initialiser.GPIO_IPConnected = GPIO_IPConnected_Disable; GPIO_Initialiser.GPIO_Alternate = GPIO_InputAlt1; GPIO_Init(GPIO7, &GPIO_Initialiser); }
Compiling states: Blinky2.axf: Error: L6218E: Undefined symbol GPIO_Init (referred from blinky2.o).
As you might guess, my experience in both uCs and C is approaching nil.
Helpful input appreciated.
Cheers Nik
"Compiling states: Blinky2.axf: Error: L6218E: Undefined symbol GPIO_Init (referred from blinky2.o)."
Actually, that would be "Linking states" as indicated by the error code's 'L' prefix, so did you include 91x_gpio.c for separate compilation to an object file to link to or add the ST library to link to?
There is probably a setting that you are missing that you might search for looking at the working Blinky example's settings.
You were absolutely right about the linking. I did now include all the *.c files for the uC. Now compiling, linking etc. works. Thanks.
