How can i page the data
I have got the RAM problem. the Data exceeds the limitations.
How can i make the data to be put in to the ROM OR implement data paging the data. Or some alternate solution?
Thanks in advance
  • "the Data exceeds the limitations"
    The first question must be: do you really need that much data?
    Are you using lots of global and/or static variables, where you could use automatic (local) variables instead?
    Are you using unnecessarily large data types? (eg, 32-bit, where 8-bit will do)
    You have already been advised to look at the MAP file:
    http://www.keil.com/forum/docs/thread9152.asp
    This will show you what's using all the memory...
