How can I force the disassembly mode in uVision ?
e.g. If the code I'm currently looking at is in THUMB mode, but I want to look at code at another address (which I know is in ARM mode), how can I tell the disassembler this ?
It often gets it wrong, and I end up with displays like this :-
0x00000000 FFFE (???) 0x00000002 EAFF ??? 0x00000004 F018 (???) 0x00000006 E59F B 0xFFFFFB48 0x00000008 F018 (???) 0x0000000A E59F B 0xFFFFFB4C 0x0000000C F018 (???) 0x0000000E E59F B 0xFFFFFB50 0x00000010 F018 (???) 0x00000012 E59F B 0xFFFFFB54 0x00000014 0000 LSL R0,R0,#0 0x00000016 E1A0 B 0x0000035A 0x00000018 FFF0 (???) 0x0000001A E51F B 0xFFFFFA5C 0x0000001C 135E ASR R6,R3,#13 0x0000001E EA00 ??? 0x00000020 0000 LSL R0,R0,#0
If there is currently no way to do this, can I suggest an optional ",A" or ",T" parameter to the address specified in the "Show Code At Address" dialog ?
Regards,
David
uVision normally derrives the code attributes (ARM/Thumb) while loading the .axf (RVCT) or .elf (GNU) file which is a elf/dwarf formatted file.
Currently there is no way to specify the mode for disassembly for those code ranges without an attribute. Disassembly can even get more worse in case of constants or trampolines within/around the code leading to nonsense output, most likely.
Did you load a hex file, or is there another reason for the code ranges without specific attributes ?
You are correct that the image was programmed from a hex file.
I have a (USB-capable) BootLoader which downloads an application image and writes it to FLASH. On startup, the BootLoader verifies the image (via CRC) and transfers control to it.
I can debug the application using uVision, but if I want to look at code in the BootLoader (or vector table) while debugging the applicationj, I come across this problem.
Is there any way to load symbolic information for more than one executable image (assuming of course that they are at different addresses) into uVision ?
My usual solution to this problem is to set a breakpoint in an interrupt handler (so that I know I am in ARM mode) and then disassemble the relevant area so that it is shown properly. This works, but is convoluted and clumsy.
I'm sure this is not an uncommon requirement.
Can I request that Keil consider implemeting a mechanism that allows the user to decide whether the diassembled code is interpreted as being in ARM or THUMB mode ?
Thanks,
David.
This might solve your problem: there is a way to load multiple files without killing the previously loaded debug info:
LOAD whatever.axf INCREMENTAL
For the first file that is loaded, INCREMENTAL is not necessary, for every following file (e.g. loaded via .ini file or somehow else) 'INCREMENTAL' is required to avoid killing all the debug and instruction coloring info collected by previous loads.
