HET usage in TMS470
I'm trying to use HET as a PWM generator in TMS470. I'm using Keil uVision 3 IDE and ARM Real View Compiler. I notice that when dynamically updating the HET memory, the memory locations are getting updated with the proper values but the output PWM waveform is not according to the value.
If anyone has any idea about this please let me know.
Also, if you have any working code for HET usage in TMS470 using Keil uVision and ARM real view compiler, please update me.
Thanks in advance,
Satya
