Storing/Reading 12 bit ADC values
Dear all,
I am using C programming and C8051F206 board. Currently, I am able to display the 12 bit data value on my alphanumeric LCD. What should i be looking at to store, say 10 discrete values from a sine wave signal with sampling frequency of 1Hz ?
Thanks.
  • I really don't understand exactly what you are asking about.
    To store 10 12-bit samples, you would normally use a 10-entry array of short int, but there must really be something else you are wondering about...
  • "I really don't understand exactly what you are asking about."
    Exactly.
    If you can read one value, then reading ten values is simply a matter of repeating it ten times!
    An array, and using a loop to do the repetition, would be the obvious choice; but you could just hard-code it as ten separate reads to ten distinct variables.
    To set the sampling frequency, you just put a delay between reads.
    So what is the real difficulty?
    Do you want to read continuously, and just keep the ten most recent values?
    If so, a Ring Buffer would be ideal...
    Note that the above is all entirely generic - not specific to Keil or the 8051...
