RL-TCPNet icmp configuration
Hi all,
is it possible to configure the icmp behaviour of the tcp/ip stack in the library? I can't find any reference to it in Net_Config.c.
Can you confirm that the icmp packets handler is configured to not reply to broadcast requests?
TIA
  • ICMP packet handler should reply to broadcast requests. It should answer broadcast ping, however you might have a collision when several hosts are sending a ping reply at the same time. This might result in some replies not being received because of a collision on the wires.
    You should use some other method to discover which hosts are alive on the net.
    Franc
