In serial EEPROM can i write the data in different locations or it should be written in sequence?
For example,
If i write the first data - 0x05 in location 0x0000, can i write the second data in 0xF000 or should i write the second data in 0x0001.
You have not stated which device you are asking about, but generally speaking, sequential write access is not required.
The device is 24FC512 serial EEPROM.
I tried to write two datas at different location but couldnt write.
But if my address is 0x0000 and write two datas continously i can write and read.
I am not sure y it cant write at different locations.
Hard to say without seeing your code.
Non-sequential addresses, each with a separate write transaction. Each transaction fully setting the device's internal address with write commencing after the stop condition starting a self-timed write, the completion of which you must either ACK-poll or implement a fixed worst-case delay.
My coding is,
#define EEPROM_WR 0xA2 #define EEPROM_RD 0xA3 sbit SCLK = P1^1; sbit SDA = P1^2; unsigned int ptr;
typedef union { float f; char b[4]; } fval;
void EEPROM_Location(unsigned int x) { ptr = x; }
void EEPROM_WrByte(unsigned char x) { I2C_Start(); //START I2C PROTOCOL I2C_Write(EEPROM_WR); //CTRL WORD FOR WRITE MODE I2C_Write((char)(ptr>>8)); //HIGH ADDRESS BYTE I2C_Write((char)ptr); //LOW ADDRESS BYTE I2C_Write(x); //WRITE THE DATA I2C_Stop(); ptr++; LongDelay(15); return; }
void EEPROM_WrInt(unsigned int x) { I2C_Start(); //START THE I2C PROTOCOL I2C_Write(EEPROM_WR); //CTRL WORD FOR WRITE MODE I2C_Write((char)(ptr>>8)); //HIGH ADDRESS BYTE I2C_Write((char)ptr); // LOW ADDRESS BYTE I2C_Write((char)(x>>8)); //HIGH DATA BYTE I2C_Write((char)(x)); // LOW DATA BYTE I2C_Stop(); ptr+=2; LongDelay(15); return; }
This routine is called as "eeprom.c" The main function code is,
extern unsigned int ptr;
void main(void) { unsigned char a,b,c; unsigned char x,y,z; a = 0x32; b = 0x45; c = 0x56; ptr = 0x0000; EEPROM_Location(ptr); EEPROM_WrByte(a); LongDelay(15); EEPROM_Location(ptr); EEPROM_WrByte(b); LongDelay(15); EEPROM_Location(ptr); EEPROM_WrByte(c); LongDelay(15); ptr = 0x0000; EEPROM_Location(ptr); x = EEPROM_RdByte(); LongDelay(15); EEPROM_Location(ptr); y = EEPROM_RdByte(); LongDelay(15); EEPROM_Location(ptr); z = EEPROM_RdByte(); LongDelay(15); }
With ptr = 0x0000, if i print the values x,y,z the output is correct. If i initialize my ptr = 0xF000, and write the data into it and read the data from same location, no output. I dont know where is the problem?
I don't see EEPROM_RdByte().
"... and read the data from same location, no output."
What does "no output" mean?
Thank you.
I had solved the problem.
