My question is: does Keil uVision support parallel ISP programmer cable?
I used the serial programmer cable to download the HEX into 89S51, as well as simulated the codes. But not sure if there is a function in uVision support parallel ISP cable as also?
Thanks indeed
www.keil.com/.../uv3_ut_runexternalprograms.htm
http://www.keil.com/support/man/docs/uv3/uv3_fl_usingflashmenu.htm
