Trying to download the Blinky program and am getting no where here on Saturday!
USB to the ULINK2 (USB LED is red and stays red? COM and RUN flash blue - is that OK? No manual to determine if that is OK or not - thanks Keil for the great documentation)
USB to MCB2300, boots OK bar graph changes with pot.
Device Manager has HID Device: Location 0 (Keil ULINK2)
Build Blinky OK
Everyting OK so far.
Try to download (COM lite on ULINK2 lights blue - is that OK?)after setting up uVision3 for ULINK and getthe pop up window:
ULINK - ARM Error: Reset the Target and try it again
Then the pop up window:
uVision3: Error: Flash Download failed - ARM7TDMI
Reset the MCB2300 and get the same above results.
Opened the ULINK2 looking for problems, lots of solder balls but nothing critical.
Any ideas?
Keil support provided an update (mdk303q.exe) to MDK-ARM that now allows downloads to work.
