HI All Just I have started working with this keil compiler.I have a doubt in setting a pin in the LH155BA LCD controller.I want to set a pin RESB to low for certain operation.How to proceed with that
"Just I have started working with this keil compiler"
Which Keil compiler? Keil makes a range of compilers - you need to specify one!
That's why the forum insisted that you select one when you made this post - you chose "Non-Specific (Generic)", but this is a specific question!
"I want to set a pin RESB to low for certain operation.How to proceed with that"
Have you looked in the Manual for your specific compiler? In particular, look at the section(s) that describe the extensions specific to that compiler for accessing hardware features...
Also be sure to work through the provided examples: http://www.keil.com/support/man/docs/uv3/uv3_examples.htm
