Hi I am developping a FX2 component from cypress but I don't know how to configure the UART0, is there any exemple anyweher?
To the superviser, I would like to answer someone that had problem with an SPI mode but I haven't found how to do.
It is real a pity to not interract with each others.
A fan of Cypress FX2 devices
I can't help you with the Cypress problem, but to answer someone, just open the thread and press the 'Reply' button to the left of the post.
Old threads can get locked - which means that you can't reply to them. If this has happened, it probably means that the original poster has long since solved (or worked around) the problem and moved on, so adding a reply now won't help them
If you really have a generally-useful contribution, you could always start a new thread, and insert a link to the old one for reference - just use your browser's usual facilities to copy and paste the URL of the thread (remember to include the full URL - then the forum automatically makes it clickable).
"FX2 component from cypress but I don't know how to configure the UART0, is there any exemple anyweher?"
If it's a standard 8051-style UART, then any of the very many 8051 examples will do! According to the Keil Device Database, this should be the case: http://www.keil.com/dd/chip/3205.htm
See: http://www.keil.com/c51/baudrate.asp
However, if it's a non-standard Cypress special, then Cypress is the place to go for help!
What does the Datasheet tell you?
Yes that was old mail that was not so old 'cause I notice that reply works
To support the SPI bus for UART in mode 0, Is that possible?
