I have been using uvision ARM for a few days now. I have a question about setting it up.
If I use the Manage Books tool I can add in references books etc. Fine. But they dont "stick", because when I change to a new project I am back to the default User's guide etc. I have tried putting my books etc in each of the three sections but to no avail.
I have also tried PC-Lint, and the same thing it looses it configuration when I change projects. Also so far I am disappointed with PC-lint. I have set it up as per the guidelines but it throws so many errors on the smallest files that it doesn't help me. There must be something wrong - I just dont know what.
The only change on the installation is that I chose to install Keil in Program files\Keil instead of C:\keil
There are General Books (for all toolsets), Tool Specific Books, and Device Specific Books.
General Books: are always available Tool Specific Books: change when you select a different architecture Device Specific Books: change with every project.
OK thanks I didn't understand the Keil help file info. Your explanation is clear. I will try again.
I dont know why PC-Lint can't be made to stick though. I have to set the configuration file, and link executional locations when changing projects
