the Evaluation version of CMX-MicroNet for the Atmel AT91SAM7X-EK board can work. but RTL-ARM HTTP Demo for SAM7X can't work. I have NOT RECOMPILE THE EXAMPLE WITHOUT RTL-ARM LICENSE. please keil test your example .
Why are you asking about IAR on the Keil forum?!
They are competitors!
"They are competitors!"
I guess Keil might say, "no competition"... ;-)
but they would, wouldn't they?!
We have tested the RTL-ARM example one more time on the Atmel AT91SAM7X-EK Evaluation Board. It just works fine. However the example needs a DHCP server in a network.
The configuration required to run the application is described in: http://www.keil.com/appnotes/docs/apnt_192.asp - under TCP/IP Connections - Connection to LAN/WAN.
Andy: RTL-ARM is a Keil product and the question was related to a Keil product.
Reinhard
"RTL-ARM is a Keil product and the question was related to a Keil product."
The title of the post is, "but IAR CMX_ DEMO program CAN wodk"
although, as you say, that doesn't seem to relate to the Keil products mentioned in the body of the post!
If he's that confused, maybe it's not surprising that he can't get it working?
Yes, I know the typical support request is today very un-structured. It is frustrating to work on such things.
This explains also why it seems to be impossible to find people that work in support.
