I am new to the microcontroller world and looking for ARM platform, which would be open, Ethernet based system, SPECIALY with I2C capability built inside, onchip, onboard or via simulation.
I would ask for information about options, which are available for ARM processors, possibly developmnet board with this ( MCBSTR9 has ethernet,.., but there is no sign about I2C)
thank you
http://www.keil.com/dd/search_parm.asp
"(MCBSTR9 has ethernet,.., but there is no sign about I2C)"
Having looked at the schematic to help another poster on this forum, I didn't find any I2C peripherals on the board, but the ARM can route its I2C subsystem signals to many different pins, some of which go to header pins where you could connect your I2C peripherals.
http://www.keil.com/mcbstr9/mcbstr9-schematics.pdf
