I use the same Conf_tny.a51 file in a project with and without bank switching. And in the project that uses banks, I have the error A45 with the STACK_ERROR object. Does someone know why it happens, and how I can correct it? Thank you
You must have mis-configured some conditionals somewhere, or otherwise accidentally "broken" it.
Go back to a working project, then take a step at a time and see where it goes wrong...
Does this help?
http://www.keil.com/support/docs/2529.htm
Jon
Thank you, I have already solved it
