Compiler warnings
We are using uVision3 V3.05c for one of my projects.
Any time I open my compiler and compile my project it gives 80 to 100 warnings. If I compile again it comes to 10 warnings which are actuall warnings. Why compiler is giving more warnings when we compile first time? is there any compiler settings I am missing? Some times, my compiler suddenly closes by indicating error on the screen, what could be the reason?
Thanks in advance
  • Don't you think it might help just a tiny bit if you said what the warnings are?
    Are you sure they are Compiler warnings - rather than Linker warnings?
    "Why compiler is giving more warnings when we compile first time?"
    Are you doing a complete build the first time, and only a partial build thereafter?
  • Hi Andy,
    Thanks for your response.
    Most of the warnings are "Warning L15 (MULTIPLE CALL TO SEGMENT)"
    "Are you doing a complete build the first time, and only a partial build thereafter?"
    I am doing rebuild all target files
    Thanks again
