Hello everyone, I've been looking some infos in Inet, but I didnt really find what I was looking for. I am working with a XC164CS32F, for my project I need various timers. Quick explanation: Timer0 : timer for my logical automat (set at 100ms) Timer1 : timer for picking values from a couple of sensors (set at 50 ms). Timer7 : I would like to generate a simple PWM signal, but as nothing was occuring, Im just increasing a dummy global variable (I will try to do the PWM on my own after being sure that the timer7 is really working!).
As far as I have debugged (and it seems to work pretty good), timer0 and 1 work perfectly. Timer7 just do not generate any interruption. My first guess was that the vector address was wrong, but it doesnt seem so. I'm using the interrupt #61 (I tried also with the 0x3D hexa value.. though I do not see the difference).
I copy/paste the code that I have for timer0, timer1 and timer7. I would gladly appreciate some help, I'm rather stucked for now! ------------------------------ TIMER0
// Initialisieren /////////////////////////////////////////////////////////////// int timer0_Init(void) { CC1_IOC = 0; // IO Control CC1_T01CON = 1; // Timer0/1 Control (16fach Prescaler) CC1_T0 = 0; // Timer0 Register CC1_T0REL = 0; // Timer0 Reloadregister CC1_T0IC = 0x007C; // Timer0 Interruptpriorität return 0; } // Timer0 Überlauf ISR ////////////////////////////////////////////////////////// void timer0_ISR(void) interrupt CC1_T0INT { automat(); } void timer0_Frequenz_setzen(float T0_frequenz) { unsigned int TimerWert; TimerWert = 0xFFFF - ((1/T0_frequenz) / 0.0000004); // min. 40 ( 40Hz ) CC1_T0 = TimerWert; // Timer0 Register CC1_T0REL = TimerWert; // Timer0 Reloadregister }
----------------- TIMER1
// Initialisieren /////////////////////////////////////////////////////////////// int timer1_Init(void) { CC1_IOC = 0; // IO Control CC1_T1 = 0; // Timer1 Register CC1_T1REL = 0; // Timer1 Reloadregister CC1_T1IC = 0x007F; // Timer1 Interruptpriorität MUSS niedrieger als Timer0 (0x007C) sein, d.H. Wert größer return 0; } // Timer1 Überlauf ISR ////////////////////////////////////////////////////////// void timer1_ISR(void) interrupt CC1_T1INT { sendFrame(MEASURE, 0); // TYPE OF FRAME = MEASURE } // Timer1 Frequenz einstellen /////////////////////////////////////////////////// // Parameter: Word (Frequenz) /////////////////////////////////////////////////// void timer1_Set_Frequency(unsigned int ui_frequency) { unsigned int ui_timervalue; //CPU-Frequenz/Prescaler ui_timervalue = (unsigned int)(0xFFFF - (1250000/ui_frequency)); // -> Minimum 20Hz! CC1_T1 = ui_timervalue; // Timer1 Register CC1_T1REL = ui_timervalue; // Timer1 Reloadregister }
------------------- TIMER7
// Initialisieren /////////////////////////////////////////////////////////////// int timer7_Init(void) { CC2_IOC = 0; // IO Control CC2_T78CON = 1; // Timer7/8 Control (16fach Prescaler) CC2_T7 = 0; // Timer7 Register CC2_T7REL = 0; // Timer7 Reloadregister CC2_T7IC = 0x007F; // Timer7 Interruptpriorität return 0; } void timer7_Reset(void) { timer7_Stop(); // stop timer7 t7_ms_counter = 0; } // Timer1 Überlauf ISR ////////////////////////////////////////////////////////// void timer7_ISR(void) interrupt 61 { bluenicecom_Send_String("! "); t7_ms_counter++; } // Timer1 Frequenz einstellen /////////////////////////////////////////////////// // Parameter: Word (Frequenz) /////////////////////////////////////////////////// void timer7_Set_Frequency(unsigned int ui_frequency) { unsigned int ui_timervalue; //CPU-Frequenz/Prescaler ui_timervalue = (unsigned int)(0xFFFF - (1250000/ui_frequency)); // -> Minimum 20Hz! CC2_T7 = ui_timervalue; // Timer7 Register CC2_T7REL = ui_timervalue; // Timer7 Reloadregister }
-------------------- I start my timers with this method:
#define timer7_Start() CC2_T78CON_T7R = 1; PSW_IEN = 1; #define timer7_Stop() CC2_T78CON_T7R = 0; PSW_IEN = 0; #define CC2_T7INT 0x3D // Interruptvektor
---------------------------------------------------- I'm a beginner in the field of microcontroller programming, I reckon my code is not optimized but well.. As said before, timer0 and timer1 work really good. But I just do know why timer7 doest not :( Any guess?
By the way, newbie question: When should the _bfld_ instruction be used? I've read the documentation on it http://www.keil.com/support/man/docs/c166/c166__bfld_.htm
Is it for masking words in SFR? once again newbie question: SFR = ? what is it actually? address in memory no (reg, control reg,..) ? read it is a kind of int, or char, then what is the point into using it?
ps: I repeat, I'm really new to microcontroller world, I know pretty good C and Java
First, you cannot have two interrupts share the same interrupt level.
CC1_T1IC = 0x007F; // Timer CC2_T7IC = 0x007F; // Timer7 Interruptpriorität
Please change one of the interrupt settings. Secondly make sure that the CAPCOM2 is enabled in the SYSCON3 register. Otherwise I don't see why you wouldn't get an interrupt on a T7 overflow. Concerning the _bfld_ instruction. It is generally used for port initialization and port control. Please have a look to the Infineon application note: AP164601 for more information. In addition to the user's manual and instruction set manual.
Ok thanks for the answer :)
