I try to run the examples for MCBSTR9. For USB HID example I can compile it, but when download to flash I got this error "No Algorithm found for: 40000000H - 400023E7H"
For USB Memory example, when I compile it I got this error ".\Obj\Memory.axf: error: L6047U: The code in this image is 46399 bytes - this version of the linker will not create images that large"
Both examples under Keil\MCBSTR9 folder
For example USB HID, I set the ram for algorithm at start: 0x40000000 size 0x8000 and pick STR91xFxx4 Flash Bank0 and set Start: 0x40000000
when I run I got this error: "Flash Timeout. Reset the target and try it again"
I reset The Ram for algorithm as the manual at start: 0x04000000 size: 0x0800
and pick STR91xFxx4 Flash Bank0 as the algorithm.
and still got error with message: No Algorithm found for: 40000000H - 400018B7H
Really need help.
Thank you
Now I download the example from keil website and download it into flash without recompile it. It worked and run on the board. But whenever I recompile the source, I can't download it into flash with error no algorithm like above thread.
There is a code size limit if you are using the demo version. It will compile all files, gernerate a map file, but will not link. (That is an experience from the C166 demo version, but might be similar.)
