Dear all,
in my program i declared some variable as constant. After compilation this program gives me some problem related to above declare variable.
Moment i remove constant from those variable my program start working correctly.
I am inital stage of debugging. Please suggest area where i need to see to solve problem.
Regards..
Yogesh
"some problem"
Do you not think that a little more detail might be helpful before anyone will be able to make any meaningful suggestions...?
In case the constant is stored in write-protected memory, make sure that you don't try to write to it somewhere in the program.
constant variable
I know this is a common expression and this specifically is not to complain about it being used, it just struck me how we get used to use totally idiotic expressions.
"make sure that you don't try to write to it somewhere in the program."
If it's declared as 'const', the compiler should give a warning about any attempt to write to it - unless it's some indirect access that the compiler can't detect at compile-time...
Yes, but it is quite easy to take the address of a const variable and send into a library function that drops the const (more than one library function have had the problem that they have taken a pointer to a const variable as input parameter, and returned a pointer to a non-const variable.
It is also much too common that people make type casts to avoid signed/unsigned warnings, and at the same time looses extra attributes, such as const.
Erik: A const variable may sound a bit strange, but since the value is actually having a memory address it is completely different from a numeric literal constant or an enumerated value or a #defined value. In a number of environments, const variables are not stored in write-protected memory, so the application may add a typecast and then use it as a normal variable.
The term "variable" is not really a 'C' thing - it is not mentioned in the 'C' standard - the term used is "identifier"
This avoids the contradictory term "constant variable".
No, an identifier is not the same thing as a variable, since an identifier is a superset that includes functions, data types etc.
"an identifier is not the same thing as a variable"
True; it would need to be specifically a data identifier - but 'C' still doesn't officially use the term "variable", as in some other languages (eg, BASIC).
//Follwing are the variable declaration in my code.
//Array Declarations:
const UINT8 alphakbd_0KeyValues[] = {"0 "}; const UINT8 alphakbd_1KeyValues[] = {"1:/\\*()#+-<>"}; const UINT8 alphakbd_2KeyValues[] = {"2ABC"}; const UINT8 alphakbd_3KeyValues[] = {"3DEF"}; const UINT8 alphakbd_4KeyValues[] = {"4GHI"}; const UINT8 alphakbd_5KeyValues[] = {"5JKL"}; const UINT8 alphakbd_6KeyValues[] = {"6MNO"}; const UINT8 alphakbd_7KeyValues[] = {"7PQRS"}; const UINT8 alphakbd_8KeyValues[] = {"8TUV"}; const UINT8 alphakbd_9KeyValues[] = {"9WXYZ"};
//Pointer to the arrays:
static const UINT8 *pArray[] = { alphakbd_0KeyValues, alphakbd_1KeyValues, alphakbd_2KeyValues, alphakbd_3KeyValues, alphakbd_4KeyValues, alphakbd_5KeyValues, alphakbd_6KeyValues, alphakbd_7KeyValues, alphakbd_8KeyValues, alphakbd_9KeyValues };
/* For debugging, when we throw first four Addresses pointed by the 'pArray' pointer. they are not maching with the addresses of first four arrays, when compared with the map file. */
Please use the pre tag for your source code.
What do you mean with "not matching"? You should be aware that, depending on the memory model, the 24bit address of your data as shown in the linker listing is different from a 16bit pointer (address) to that data when debugging. Here is an example:
Say, the address of your constant data is 0xC116E8 in the linker listing. While debugging, you would see this address as 0x56E8. Why? The 16bit address is a 14bit page offset (bits 0~13)
0x56E8 & 0x3FFF == 0x16E8
and a 2 bit data page pointer (bits 14~15)
(0x56E8 & 0xC000) >> 14 == 1 i.e. we use DPP1
The lower 10 bits of each DPP register select one of the 1024 possible 16-Kbyte data pages. In our example, DPP1 is 0x0304, so it selects page 772, i.e. the page base address is 772 * 16384 == 0xC10000 which perfectly explains the listing address:
0xC10000 | 0x16E8 == 0xC116E8
You should check the user manual of your processor for further details on addressing.
Thomas
