It's somewhat like look-up table of assembly. I defined an array in header file of C program like this: unsigned char code volt_2_freq[5]= { 100, 200, 300, 400, 500 }; Can I put it in a specific address of code memory ? I use Phillip LPC900 series MCU and want to set security bits of "MOVC disable" in certain program memory blocks which the array can't be put in. Does keyword "_at_" work ? Thanks~
willy
"Does keyword '_at_' work"
The _at_ keyword works exactly as described in the Manual - unfortunately, that precludes initialisation! :-(
This question is asked so frequently that it's amazing that Keil haven't removed the restriction yet!
The solution is described in a knowledgebase article - use the site 'Search'; basically, you need to use the linker to set the address.
"I use Phillip LPC900 series MCU and want to set security bits of 'MOVC disable' in certain program memory blocks which the array can't be put in."
I don't think that's been mentioned before as a reason for doing it, though!
instead of _AT_ I have all XDATA in an ASM module like (extract)
;;//////////////////////////////////////////////////////////////////// ;; ;; FILE: SLVXDATA.A51 ;; ;; Copyright TwinVision N.A., 2006 ;; ;; Xdata buffers (in assembler to force sequence and XendOfMem define) $NOMOD51 ;$INCLUDE (sdefs.h) ;$INCLUDE (msstruct.inc) PUBLIC GCXSinBuf PUBLIC GCXSouBuf ..... ?XD?xdataf SEGMENT XDATA RSEG ?XD?xdataf ...... ;; --- these located as early as possible for the sake of the speed of internal RAM ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; the next 5 buffers MUST be kept in the current order and contiguous GCX1_2Buf0: ds 01000h ;byte per dot 256 cols, 4 rows GCX1_4Buf0: ds 01000h GCX1_8Buf0: ds 01000h ....
then my .h file define all XDATA as extern
"This question is asked so frequently that it's amazing that Keil haven't removed the restriction yet!"
In fact, the version of _at_ in the ARM compiler does allow initialisation: http://www.keil.com/support/man/docs/ca/ca_le_absvarloc.htm
So why can't C51 allow it??
