#pragma ASM/ENDASM inside a #define (???)
I'm having trouble using #pragma ASM/ENDASM inside a #define statement. This is what I want to do inside the #define:
- push ACC (assembly)
- push IE (assembly)
- EA = 0 (C)
This is the code I'm *trying* to use:
#define portENTER_CRITICAL() \
#pragma ASM \
push  ACC \
push  IE  \
#pragma ENDASM \
EA = 0; \
But I always get an error, no matter what I change... also, it seems that #pragma ASM/ENDASM can't be used inside header files (who knows why...), is there any workaround for that, without repeating the same #defines inside all .c files that uses it?
Best regards,
Carlos.
PS: any one answering this thread, nevermind the "that's a bad practice! use separate asm and c source files! blah blah!..." comments... I really need this, so don't bother with those kind of comments...
