Hi, How do i generate a delay of 50nS using C.is there any NOP instruction in ARM7.i dont want to use timer or interrupt.please help
Regards, Divya
nS is nano seconds,
No, that is what you want it to be. But it isn't. The internationally standardized symbol for the SI unit 'second' is still a lower-case 's'.
And you're thorougly misled about your choice of techniques. You say you "don't want" to use timers for this job, when timers are exactly what you should use for it. More to the point, you should be using some kind of hardware PWM generator fed off a timer. 20 MHz is way too high a frequency to be done by software-only methods, even on an ARM.
Sorry that I put my post before yours. Sometimes, my posts are not accepted immediately - the site complains about my mail address. When I come back later, I have to try to post again :(
