Hi to every body
I use uVision3 for compile a program.My program have some of .h and .c files. In one of them that called "guts.h", I define :
typedef struct yaffs_DeviceStruct yaffs_Device; typedef struct { __u8 tagByte0; __u8 tagByte1; __u8 tagByte2; __u8 tagByte3; __u8 pageStatus; __u8 blockStatus; __u8 tagByte4; __u8 tagByte5; __u8 ecc1[3]; __u8 tagByte6; __u8 tagByte7; __u8 ecc2[3]; } yaffs_Spare;
and in other file that called "mtdif.h", I define like this:
#ifndef __YAFFS_MTDIF_H__ #define __YAFFS_MTDIF_H__ #include "yaffs_guts.h" int nandmtd_WriteChunkToNAND(yaffs_Device * dev, int chunkInNAND,const __u8 * dat, const yaffs_Spare * spare); #endif
But it has error. The error is : "undefined yaffs_Device"
But when transfered this code to mtdif.h the error removed:
what is the problem? The problem when increase that I include guts.h in some of my files. In all of files that use variables that defined in "guts.h" has error. what is problem? what I do for solve it?
Thanks very much
hi zsa zsa,
where you you youuuuu define yaffs_DeviceStruct ????
K
In guts.h
The code you posted does not show a definition for yaffs_DeviceStruct.
Please post the full, complete error message - use copy-and-paste, do not manually re-type it.
... or do you also get other errors?
Remember: one error can lead to another...
Definition of yaffs_DeviceStruct in guts.h :
struct yaffs_DeviceStruct { struct list_head devList; const char *name; int nDataBytesPerChunk; int nChunksPerBlock; int nBytesPerSpare; int startBlock; int endBlock; int nReservedBlocks; int checkpointStartBlock; int checkpointEndBlock; };
The error is :
MTDIF.H(22): error C141: syntax error near '*', expected ')'
Please re-post that, using the 'pre' and '/pre' tags - as you did in your original post.
Use the 'Preview' button to check that it's worked proerly before you post.
"The error is :
MTDIF.H(22): error C141: syntax error near '*', expected ')' "
That's not what you said originally, is it?
What line, exactly, does it refer to?
hi zsa gar,
you first code saysing
but file is guts.h ???
what is who???
you not give all code!!!
list_head not definededed!
i make project you see and works??
BUT i put in struct for jist_head
code is good
"you first code saysing
but file is guts.h ???"
Exactly!
And now you're posting an error in MTDIF.H - which you haven't shown at all!
I think you need to go back a few steps and get your header files sorted out?
