Hello all,
while checking the code given here. www.maxim-ic.com/.../3524 I found that Keil compiler is not generating the correct code required for the following commands in C
spiTmp = spiData[i]; SCK_PRE; MOSI=spiTmp7; SCK_MID; spiTmp7=MISO; SCK_POST; // bit 7 SCK_PRE; MOSI=spiTmp6; SCK_MID; spiTmp6=MISO; SCK_POST; // bit 6 SCK_PRE; MOSI=spiTmp5; SCK_MID; spiTmp5=MISO; SCK_POST; // bit 5 SCK_PRE; MOSI=spiTmp4; SCK_MID; spiTmp4=MISO; SCK_POST; // bit 4 SCK_PRE; MOSI=spiTmp3; SCK_MID; spiTmp3=MISO; SCK_POST; // bit 3 SCK_PRE; MOSI=spiTmp2; SCK_MID; spiTmp2=MISO; SCK_POST; // bit 2 SCK_PRE; MOSI=spiTmp1; SCK_MID; spiTmp1=MISO; SCK_POST; // bit 1 SCK_PRE; MOSI=spiTmp0; SCK_MID; spiTmp0=MISO; SCK_POST; // bit 0 spiData[i] = spiTmp;
NOTE: Here the spiTmp variable is getting modified bitwise. And then the modified byte is again copied back to spiData[i] variable
It generates this assemble code
; SOURCE LINE # 80 0004 7400 R MOV A,#LOW spiData 0006 2F ADD A,R7 0007 F8 MOV R0,A 0008 E6 MOV A,@R0 0009 F500 R MOV spiTmp,A ; SOURCE LINE # 81 000B C282 CLR SCK 000D A200 R MOV C,spiTmp7 000F 9283 MOV MOSI,C 0011 D282 SETB SCK 0013 A284 MOV C,MISO 0015 9200 R MOV spiTmp7,C ; SOURCE LINE # 82 0017 C282 CLR SCK 0019 A200 R MOV C,spiTmp6 001B 9283 MOV MOSI,C 001D D282 SETB SCK 001F A284 MOV C,MISO 0021 9200 R MOV spiTmp6,C ; SOURCE LINE # 83 0023 C282 CLR SCK 0025 A200 R MOV C,spiTmp5 0027 9283 MOV MOSI,C 0029 D282 SETB SCK 002B A284 MOV C,MISO 002D 9200 R MOV spiTmp5,C ; SOURCE LINE # 84 002F C282 CLR SCK 0031 A200 R MOV C,spiTmp4 0033 9283 MOV MOSI,C 0035 D282 SETB SCK 0037 A284 MOV C,MISO 0039 9200 R MOV spiTmp4,C ; SOURCE LINE # 85 003B C282 CLR SCK 003D A200 R MOV C,spiTmp3 003F 9283 MOV MOSI,C 0041 D282 SETB SCK 0043 A284 MOV C,MISO 0045 9200 R MOV spiTmp3,C ; SOURCE LINE # 86 0047 C282 CLR SCK 0049 A200 R MOV C,spiTmp2 004B 9283 MOV MOSI,C 004D D282 SETB SCK 004F A284 MOV C,MISO 0051 9200 R MOV spiTmp2,C ; SOURCE LINE # 87 0053 C282 CLR SCK 0055 A200 R MOV C,spiTmp1 0057 9283 MOV MOSI,C 0059 D282 SETB SCK 005B A284 MOV C,MISO 005D 9200 R MOV spiTmp1,C ; SOURCE LINE # 88 005F C282 CLR SCK 0061 A200 R MOV C,spiTmp0 0063 9283 MOV MOSI,C 0065 D282 SETB SCK 0067 A284 MOV C,MISO 0069 9200 R MOV spiTmp0,C ; SOURCE LINE # 89 006B F6 MOV @R0,A
See the code generated for line 89. It should be
MOV A,spiTmp MOV @R0,A
or directly
MOV @R0,spiTmp
I think its because the byte spiTmp is getting modified bitwise and that by no way the compiler is knowing that the byte is modifed and it has to read back the variable and copy the same to the destination.
I tried almost all the setting options for C51 (Code optimisation, warnings etc.), starting with default setting. And that I am using the latest version of the compiler from Keil.
It will be a great help if experts throw more light on this.
Thank you.
Regards, Shriram
Qualifying spiTmp as "volatile" might help.
Hi Dan,
I already tested it, and it works fine. But then why not the way as it is?
Shriram
How are spiTmp and spiTmp' 0-7 declared? Is spiTmp is bdata? Can you post the defining declarations?
Shriram Patki: "I think its because the byte spiTmp is getting modified bitwise and that by no way the compiler is knowing that the byte is modifed and it has to read back the variable and copy the same to the destination."
I think you are right!
I seem to remember having seen this in the distant past some time before... What version are you using?
Dan Henry: "Qualifying spiTmp as 'volatile' might help."
Shriram Patki: "I already tested it, and it works fine. But then why not the way as it is?"
See above - I think you have already answered that! If your hypothesis was correct (and I think it was), then you would expect 'volatile' to fix it, wouldn't you?
This does sound like a flaw in the bdata implementation - the compiler should know that these are all references to the same bit-addresable object!
Definition: A "Feature" is a Bug that has been documented!
"I seem to remember having seen this..."
Ah yes, here it is:
http://www.keil.com/support/docs/1863.htm
Note that this is linked direct from the online manual page:
http://www.keil.com/support/man/docs/c51/c51_le_bitaddrobj.htm
But I think it should be properly included in the Notes on the page - not just added as a link.
Andy and Dan, thanks.
Dan, it was declared as
usigned char bdata spiTmp;
Andy Neil: "Definition: A "Feature" is a Bug that has been documented!"
Do you mean to say, A Bug I thought was a "Feature" that has been documented!? :)
Andy Neil: "But I think it should be properly included in the Notes on the page - not just added as a link."
Yes, I agree. It should be included there.
Thanks to both of you.
